Archived from groups: microsoft.public.windowsxp.general (More info?)
Ok here is my problem in the most detail i can give.........I believe somehow
Windows XP Home Edition is running in 16-bit mode.....The Reason why I think
this is because that i cannot run 32 bit dos programs and such as cmd.exe or
others that require a 32 bit. I dont have to re install windows to correct
this do I? And if I don't how do i go about fixing it....Thanks in advanced.
Cmd isn't a Dos program (there are such things as 32 bit dos programs but windows doesn't have any but can run some of them - a lot of old dos games were 32 bit sort of). It is a console program. Dos programs also are console programs.
What happens.
http://webdiary.smh.com.au/archive [...] 01075.html =================================================
"Master Jedi" <MasterJedi@discussions.microsoft.com> wrote in message news:FD401FEF-3F28-4EA4-A341-802564705246@microsoft.com...
ok this is the error message is recieve........ and the title of the form
is 16-bit MS-DOS SUBSYSTEM
C:\windows\system32\cmd.com
C:\windows\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running
MS-DOS and Microsoft Windows applications. Choose 'Close' to terminate the
application.
Buttons: Close Ignore
and when i press Ignore the program terminates anyways.....so what do I do????
> What happens.
> http://webdiary.smh.com.au/archive [...] 01075.html > =================================================
Try going to start, run. Type cmd and hit enter. Have you run your antivirus
software? Removed all spyware?
> application.
> > What happens.
> > http://webdiary.smh.com.au/archive [...] 01075.html > > =================================================
You have or had a virus that deleted autoexec.nt. Replace it. You have more than one copy on your disk.
"Master Jedi" <MasterJedi@discussions.microsoft.com> wrote in message news:36BD65E1-887B-4F7A-AEE9-97AD210B3CD6@microsoft.com...
> application.
>> What happens.
>> http://webdiary.smh.com.au/archive [...] 01075.html >> =================================================
> form is 16-bit MS-DOS SUBSYSTEM
> running MS-DOS and Microsoft Windows applications. Choose 'Close' to
> terminate the application.
> I do????
>> What happens.
>> > believe somehow Windows XP Home Edition is running in 16-bit
>> > mode.....The Reason why I think this is because that i cannot run
>> > 32 bit dos programs and such as cmd.exe or others that require a 32
>> > bit. I dont have to re install windows to correct this do I? And if
Error message when you install or start an MS-DOS or 16-bit
Windows-based program:
You can put back the standard version of autoexec.nt/config.nt by
copying a backup copy held in %windir%\repair\ to %windir%\system32\
(%windir% is typically C:\Windows) instead of using the procedure in
the KB article above.
you answered my questions thank you....also yes I did indeed have
AVAST....sigh it was such a good virus removal tool........sigh....but now im
going to use BitDefender....
> > I do????
> >> What happens.
> http://support.microsoft.com/defau [...] duct=winxp >
> This can also be caused by malware.
> Also, AVAST (antivirus software) can be the cause if you have WinXP SP2
> installed:
> http://groups.google.com/groups?th [...] omcast.com >
> Malke
> MS-MVP Windows User/Shell
> Elephant Boy Computers
> www.elephantboycomputers.com > "Don't Panic"
