Viewsonic NX3251W LCD power issues
Hello,
My LCD TV does not power up. The power LED no longer lights up. Any ideas? The screen is totally black.
2 answers Last reply
More about viewsonic nx3251w power issues
  1. With the set unplugged, remove the back cover. First stop is the power supply.
    First, check the line fuse. If it is wrapped in white tape, you may have to use the back-to-front feature of a multimeter to check, or just replace it. After that, check the fuse above the transformer on the Hot side of the board. Next, check for domed, leaking or bulging capacitors that may need replacement. No indicator makes me look at the power supply first.
  2. Quote:
    Hello,
    This is a complicated isssue that requires a lot more than changing a fuse. It should be forwarded to a service center. High voltage inside, do not recommend you work on it. :non: :non: :non:
HDTV Viewsonic LCD Power Up LED Monitor Power Home Theatre
