To open with I did search the forums and find some similar posts, however there was no apparent solution other than disabling sleep mode or rolling back drivers neither of which are solutions acceptable to my company.
I've recently started having a BSOD appear on my work laptop (HP Pavilion dm4), it seems to be when the laptop is shutting down to 'sleep' mode, at around the same time these bluescreens started up there also started to be connectivity issues with the wireless on board, it will connect for a variable amount of time, then simply drop the connection, usually for at least 20 minutes before reconnecting to the wifi, if I attempt to disable/re-enable the wireless card it seems to lock up in the midst of that process effectively forcing a restart. There have been no new drivers installed on this machine (all the drivers on the hp website are dated before the apparent manufacture date) and disabling sleep mode is unfortunately out of the question.
I can provide the minidump if that would be helpful, at this time I'm just looking for a direction to look in, as other than the apparent correlation between the blue screens and wireless issues I don't have many clues.
thanks for any help you guys can offer.
