Closed
Powering camera using USB power
Last response: in Digital Camera
March 24, 2011 1:18:22 AM
I want to power my camera using USB power.
The camera is a Canon S95 and takes 3.7V (1000mAh) batteries which read an output voltage of about 4.1 when charged.
I want to keep the camera on for a long period of time so is it safe for me to use a few resistors (which I did) and decrease the USB output voltage to 4.1 and power the camera that way?
Will this cause damage to the camera?
Do milliamps also play some role in this that I haven't yet considered?
a b w Digital camera
March 27, 2011 9:31:59 PM
USB 2.0 has usually 500mA which might be adequate for the camera. Worth trying.
Score
March 28, 2011 2:35:47 AM
I tried that but nothing happened.
Score
March 28, 2011 11:34:40 AM
That means that the camera needs more power than the USB can deliver. Similar to external HDDs connected to USB without the power adapter connected.
Score
March 29, 2011 3:45:02 AM
I kind of already figured that.
I'm just wondering if powering a camera using an external power source means that a certain amperage is needed and if using more than the amperage of the batteries would cause damage to the camera.
Score
March 29, 2011 1:39:15 PM
When you know it is not working, stop! Clearly, more amps are required than the USB port can supply. Why find out whether damage could happen?
Score
March 30, 2011 4:13:52 AM
Well I don't really want to know if it'll get damaged; I don't want to damage it.
I'm trying to find out how many amps the power source needs to be able to power the camera (since I want the camera on for long periods of time).
If the batteries for this camera have a capacity of around 1000mAh (and output around 4v), does that mean I need a power supply that outputs around 4 volts at 1 amps? Does amperage work the same way for batteries as it does for regular dc power supplies?
Score
Best solution
March 30, 2011 1:04:14 PM
Capacity is in Amp-hours. 100 Amp-hours could be 1 Amp for 100 hours OR 100 Amps for 1 hour (not a linear relationship).
Somewhere on your camera or in the manual, the Watts may be stated. This is a better indication for the Amp draw. In DC circuits, Watts = Amps X Voltage. From this you can do the calculations.
January 28, 2012 5:24:03 PM
Best answer selected by mousemonkey.
Score
January 28, 2012 5:24:05 PM
This topic has been closed by Mousemonkey
Score
