Archived from groups: rec.games.miniatures.warhammer (More info?)
Newsgroups: rec.games.miniatures.warhammer
Sent: Monday, February 28, 2005 6:58 AM
Subject: [40k] 1500 point salamander army for review
> HQ - Reclusiarch, bp, frag, jump pack 107
> (leads the assault marines)
> T - 5 Scouts, 3x sniper, 1x bolter, 1x heavy bolter 85
Best to either stick to bolters to keep the points down, or give everybody a
sniper rifle.
> T - 5 scouts, 1x missile launcher, 4x bp+ccw 75
Not all that effective - small scout squads used for assault tend to vanish.
Cut these guys & use the points elsewhere.
> T - 9 marines, 2x flamer 151
> veteran, bp, p fist 45
> rhino, smoke, armour 58
> T - 6 marines, 2x melta 115
> (tank hunting and/or support for the other rhino squads)
These three are good. Maybe some meltabombs on the Vet Sgts (it's the only
way to be sure...)
> FA - 4 assault marines, 2x plasma pistol 98
> veteran, bp, p fist 52
It's really worth diverting points from elsewhere to up the size of your
assault squads. They tend to draw a lot of fire, and don't have the benefit
of a transport to protect them.
> H - 8 devastators, 4x missile launcher 200
Maybe drop the size by a model or two, and ditch one ML to make up the
points you could use elsewhere.
> H - Whirlwind 85
You can never go wrong with one of these...
This is very similar to my usual 3rd Ed army, with the emphasis being on
close range fire-fights with assaults to mop up the survivors. The problem
starts when your transports get blown out from under you in turn 1, but
you've already done as much as you can to help prevent that. Consider taking
a Predator instead of the Devestators, and if you can shoe-horn in another
transport then you have a highly mobile force. If you need to rush the enemy
you present him with so many targets that something is bound to get through!
Razorbacks are good transports for fire support squads for this reason - you
don't mind so much if the squad has to disembark.
> sniper rifle.
At the moment I only have 3 sniper scouts, and I guess the poor bolter
scout should be viewed as ablative armour for the snipers.
These guys job are not primarily cc but to give me an infiltrating
missile launcher, which sounds like a very good thing in theory at least.
I'll consider dropping them or making them a full-sized squad.
>> T - 6 marines, 1x plasma, 1x lascannon 115
> Classic. Lascannon & friends.
> way to be sure...)
I thought that was 'nuke it from orbit' rather meltabombs...
Meltabombs will be added if I free up the points for it.
I have a box of unassembled assault marines so I could increase the
squad size easily given points, time and glue. With the current
squad-size I was planning on keeping them out of LOS for counter
charge, or keeping them close to the rhinos and use the rhinos as
mobile cover.
Ok.
>> H - Whirlwind 85
My orks have been on the receiving end of a whirlwind far too many
times...
I used a predator in my last game but was very unimpressed by it's
performance. It spent most of the game stunned/shaken until it finally
blew up. Better deployment could have helped some, but the 'hull
down'-rules are not quite as generous anymore. Getting 'hull down'
without obscuring at least one of the sponsons is quite tricky.
"jockelinde" <nouser@notmydomain.se> wrote in message
news:slrnd261om.b7q.nouser@crux.id.gu.se...
<snip>
>> only
>> way to be sure...)
For some reason that option was left out of the codex...
Hows this for a troop option:
Exterminatus - counts as 1 HQ & 2 troops and automatically costs the same as
your opponent's entire army.
Game is automatically a draw.
That should save all the rules arguments & allow more time for beer &
pretzels!
>> benefit
> mobile cover.
Both valid, but very hard to do against mobile enemies. I developed a whole
tactic that revolved around using 3 rhinos & a razorback to break up LOS in
the middle of the table (like blind grenades in 2nd ed). My guys would all
jump out to one flank, and by the time the bulk of the enemy had maneuvered
to shoot again there was a fair chance I had done enough damage already
<snip>
Fair opinion - I've never even owned one. I prefer the Vindicator - nothing
attracts fire quite like it does! Now that it can fire on the move, all you
have to do is buy it a dozer blade & deploy behind cover. Your first turn,
drive far enough forward to be able to see. No more first turn blues
That being said, it sounds like your pred absorbed a lot of fire, a useful
role in itself!
><snip>
>>> only
>>> way to be sure...)
> pretzels!
Excellent plan for efficiency increase!
<snip>
A vindicator is very appealing, but unless I can find one cheap I'll
wait until there is a vindicator kit based on the new rhino hull.
> role in itself!
> news:slrnd264fm.b7q.nouser@crux.id.gu.se...
> You could always get the FW version. Much nicer than the GW kit. You have
> bottomless pockets, right?
Unfortunately not, so there won't be any FW orders from me.
news:slrnd26dlt.b7q.nouser@crux.id.gu.se...
Shame, the FW vindicator is £5 more than the GW one but at least it's based
on the new rhino chassis, and looks nice.
That's not quite as expensive as I expected and I have now taken a
look at it. Overall it's a very nice model, but the gigantic dozer
blade/blast shield/whatever ruins it for me.
news:slrnd28hiv.m3e.nouser@crux.id.gu.se...
>>>> have
>> based
You could probably dump that on eBay and recover some, if not all, of the
additional cost
