This is the last piece of my system that I will be ordering very soon and I just can't make up my mind and would like some help.
I'd like a 22" but not stuck to that size. I don't want to spend more than $250. There will be some casual gaming probably FPS if anything. Also graphic work so color accuracy is a good point and just general computer use web, browsing etc..
I've never owned an lcd except in my notebook and I'm spoiled with an Ezio at work but cannot decide what would be the best for the best money for home. Help!! Thank you
If you want some color accuracy, the Dell 2209WA is the only choice worth buying in that category. Unlike every other monitor in that price range, it has an IPS screen. It absolutely FLATTENS everything else below $400 for color accuracy and image quality.
What is the difference between these two. I'm going to buy one or the other and right now just at looking at the specs I like the 2209WA even though the S2209W has higher resolution. I'm looking to buy this asap.
The 2209WA is much better. It is an IPS panel --- very accurate rendering of colors, and the viewing angle is very generous. It's extremely rare to find an IPS panel at this price range (they are usually in the $500+ category). Don't confuse the 2209WA with with the 2209W model, which is a TN panel. Those have very narrow viewing angles and inaccurate color rendition.
