Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Laptop having BSOD and Freezing Problem Help
Forum Laptops & Notebooks : General Laptops & Notebooks - Laptop having BSOD and Freezing Problem Help
OKay just got my msi 1651 back and the bios is replaced and up to date. I even reformated my computer and installed the new windows 7 drivers.
I have a ms 1651
9600m GT ddr3 512mb
T9600
4gb of ram
5300 wifi card
I have ran diagnostics to see anything wrong with computer. Nothing. I get bsod on any game ill be playing. Not sure if its the graphics card dyeing out on me or the processor. I have also put windows vista 32bit home premium and i still get bsod on it.
i get 0x00000214
0x00000016
or if the computer doesnt get bsod after i get bsod once mmy computer freezes up after about an hour of just doing normal stuff. if anyone can help me please help as sson as possible.
Nothing with sofware i have done everything microsoft has told me i think it might be my graphics card but i am not sure.
Sponsored Links
You've got a hardware fault on your hands if changing the OS didn't change the problem.
What diagnostics did you run?
Reply to frozenlead
i have run ultimate boot cd and also the geek squad disc as well.. says nothing is wrong with anything passes all the test. drivers are up to date. everything with the bsod the 0xetc always points to my video card.
Reply to Espada
If that's the case, and you've tried all the drivers you can find, then you're right, it's your GPU.
Record it's idle and load temperatures to check if it's overheating.
Reply to frozenlead
idle as of right now is 50 im playing the game it is about 75
Reply to Espada
76 is the highest i have seen the temp go on my gpu. cpu doesnt go above 55
Reply to Espada
Well, your temps are fine. If all your diagnostics passed, your board/GPU is probably at fault. If it persists through OS installs, you should probably replace them both. You can still try breadboarding the notebook.
Reply to frozenlead
so far i have had no problems with it so far i put it to be compatabile with vista sp2 on css and aion i have been playing for 3 hours straight havent gotten it once!
Reply to Espada
There are 962 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
  • 01:00 dabell won the Uniformed badge
  • 01:00 zebo56 won the Uniformed badge
  • 01:00 drkkmittal won the Uniformed badge
  • 01:00 jakesvdyk won the Uniformed badge
  • 01:00 artistjane won the Uniformed badge
