I recently bought some new computer parts and installed them. I downloaded Sandra software and checked out my computer specs. According to the software my FSB runs at (2x1000) Mhz, but my memory bus speed is only 2x230 mhz. How do i overclock my RAM to match my frontside bus speed? Or how would i get a suitable ratio.
No I never made any adjustments to the RAM or the FSB. That is standard settings by whatever Abit put in.
I can get a screenshot of the Sandra output in about an hour or so.
Maybe im mistaken but i thought the whole point of having dual channel ram was to exceed the 400 mhz ram speed.
The way I understood if you had dual channel ram each running at 400 mhz you could get close to a total of 800mhz on your ram speed. Like i said i could be wrong,im not the best with hardware.
my board also comes with this utlity called uguru from abit.. it allows me to OC my system through windows.. ill take a screenshot of it also so you can see the voltage settings.
the memory is at 2x204 mhz (408mhz)
<P ID="edit"><FONT SIZE=-1><EM>Edited by Bob369 on 07/19/05 01:11 PM.</EM></FONT></P>
The support list are incomplete. All of them are. Your board supports PC4000, PC4200...
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
well i have come to find out that the uguru utility i have in windows overclocks everything. The way it overclocks my FSB speed = my CPU speed. Now thats pretty amazing. It also overclocks my memory by the same mhz rating.
CPU 2400 mhz = FSB 2x1200 mhz = MEM 2x(2x240) mhz
but thanks for the help anyway... i didnt reallized that it did it all together.
thanks for posting about the RAM crash ill check into that some more and see.. i just bought my RAM though so i doubt im going to be changing it out anytime soon.
I do have a couple questions though.. say i overclock my RAM to 240 mhz from 200 mhz. How would i test the stability of my system? Use it and see how it runs?
And if it is slighly unstable do i increase the VDDR to make it more stable?
<P ID="edit"><FONT SIZE=-1><EM>Edited by Bob369 on 07/20/05 08:24 AM.</EM></FONT></P>
yes my FSB runs at that speed.. at default setting it runs at 1000 mhz. With the 64 bit socket 939 processor you can get a FSB that high using the Hyper Transport Technology. I get the 1200 mhz when I OC it. If you dont believe me you can check out my board... http://www.newegg.com/product/prod [...] 6813127187
My motherboard has built in temperature sensors for the CPU and the board. With the Abit utlities I can monitor them in Windows.
I was usuing Sandra 2005 and it said i get 2x1200.. im assuming that you get the 2x (2400 mhz) by considering both directions but im not postive about that
<P ID="edit"><FONT SIZE=-1><EM>Edited by Bob369 on 07/20/05 10:04 AM.</EM></FONT></P>
Actually, that is the fsb. Hypertransport is an FSB protocol. What 'everyone' calls fsb is the clock signal sent to the CPU, not the FSB (but only for the A64 - everywhere else its' the FSB speed).
Mike.
<font color=blue>Outside of a dog, a book is man's best friend. Inside the dog its too dark to read.
-- Groucho Marx</font color=blue>
Yes, VDDR can be used to increase memory stability. Most modules should be able to handle 2.80v fairly easily, but some are designed to tolerate even more.
yeah i was experimenting last night and had the CPU and everything cranked up to like 2500 mhz.. then change the vddr to like 3 and my comp shut off lol.. a quick reset of the cmos fixed that.
my latency on my RAM is like 2 but my VDDR is set to like 2.6. Generally, does bumping up by say .1 or .2 make a big difference in stability or should i increase it by more?
My PC:
Abit AX8 Socket 939 VIA K8T890
AMD Athlon 64 3200 Winchester
Sapphire Radeon X700 Pro 256 Mb PCIe
WD Raptor 37 Gb SATA
Corsair 2x512 PC3200 DDR Dual-Channel Platnium Edition
.1 or .2 can provide a big increase in stability, but it's not garunteed. More can help only a few modules that are designed for it.
