I brought a WD Raptor 74Gb hard drive last week i knew my motherboard (GA-7N400) didn't have a Sata port so i brought a PCI Sata Card with 32bit interfaceing.
I installed the sata PCI card and connected the Raptor drive. I also installed the drivers for the card and installed Windows XP SP2 onto the WD Raptor hard drive. The WD Raptor drive worked fine windows loaded as normal. The problems started when I install my old 40gb Seagate ide 7,200 hard drive as a slave.
The probalem is as soon as i plug in the old ide hard drive it over-rides the new raptor hard drive (with windows xp installed) and loads up old ide hd (windows xp is still installed on the old hard drive). I changed the pins on the ide hard drive to slave and checked the raptor pins is set to master and i still get the problem. I checked the bios and i noticed this earlier in the installion of the raptor drive that the bios didn't/doesn't detect the raptor drive through the PCI card. Even though it starts up fine as a single hard drive the bios doesn't show up the hard drive. The bios shows the old hard drive as slave drive (secondary drive) and loads up windows from that hard drive. How do i get the bios to recogonize my raptor as the master drive and the old ide as a slave drive? where am i going wrong...
Aaron
Aaron
