Battery charger trouble
ermaclob
7
im trying to recharge a battery for a old camcorder i have. i bought a battery recharger that "support" various battery models. the problem im having is that i put the battery in to charge and it does so for 2 in a half minutes and then the charger lights up a green light that says charged when it really is not. if i leave it in it will not charge. if i unplug it and plug it back in it start to charge again for 2 more min and the terns green again. i dont really know what to do at this point. any one have any ideas for me??
BTW the battery says it 6V 1.2Ah and the charger says it outputs 10.3V at 550 mAh
the charger states that it can charge 3.6/3.7V, 7.2/7.4V,and High Cap batterys. but is also meant for other battery's that fit it
Christine_11
I too have an older large Sony camcorder and have not been able to charge the battery? I will be interested to see what you come up with. Mine used to plug in, and charge through the recorder, but the last time I plugged it in, nothing?
