SETI Problems
bdaley
609
Ever since I upgraded SETI to the newest version (3.03)I've been having some strange problems. My monitor will no longer shut itself off after the time I've specified, and the screensaver sometimes gets set back to "none" so SETI doesn't even run.
Has anyone else had similar problems?
Thanks.
"There's no such thing as gravity, the Earth just sucks"
scarecrow
578
Thats a strange problem.
Try uninstalling and then download the 3.03 version again and try re-installing. You'll loose the progress on the unit you were working on but not the wu. Let us know if this works.
<A HREF="http://www.seti.tomshardware.com" target="_new">Join The Tom's Hardware SETI@Home Team</A>
