Im running a server with a scsi raid 5 configuration. Problem was that earlier today when I came to work 2 of the disks suddenly didnt work anymore. After fooling around with the slots I got 2 of them to work on slot 0 and 1, but 2 didnt want to cooperate leaving me to put a disk in slot 3. The problem here is that its imperrative I dont loose any data from the disks, as they contain alot of important sales information. So this leaves me with 3 questions.
1. Can I change around the disks on an array without it mattering for the total data. So that I can f.eks start up the computer after swaping disks 0 and 1 with each other and the system will go unchanged.
2. Can I leave slot #2 open and move right to slot #3, rebuild the array and it will work?
3. If yes on 2, when I rebuild the array will I loose any of the information I have on the disks? As I understand it as long as 2 of the disks works I should be able to retrieve all the data even if disk 3 in slot 2 didnt work.
Im unsure of what raid controller I am using as Im not the one that set up the system, but the bios Im running is Megaraid WebBIOS 1.38 (couldnt find any manuals or anything on this bios by google, appart from basic specs and info). This is a difficult problem, but any extra info that might help me out would be appreciated.
