LCD TV Problems
Have a 42 inch lcd tv the left half of the screen is solid vertical lines, some think some thin. Different colors, part,toward the middle is see through pinkish and fuzzy. Its an Optima bought at a yard sale was hoping to repair any help will/is greatly appeciated.
3 answers Last reply
More about problems
  1. Replace circuit boards and connectors 1 at a time. If that doesn't work replace screen. If you don't have the spare parts, give us the voltage readings of the power supply.
  2. Either a bad panel or a bad t-con (connector between the screen and the mainboard). If you whack on the back of the cabinet, center-top, and it gets better - chances are a bad t-con.
HDTV TV LCD Home Theatre
