Im looking for 22 in monitors that can run games at 1920 1200 res and so far ive only found 1 and thats the lenovo l220x. Its a good monitor but its very expensive, $500 i believe. So im wondering if there is any other 22in monitors you guys know that can run at 1920 1200 res, if not i guess ill get this 1, i dont have enough room for a 24 and i want 1920 1200 res lol.
Yes, there are others, but they are even more expensive. That is basically because they use LCD panel technology that is more expensive to manufacture. It's called S-PVA.
Most 22" LCD monitors use TN panel tech and are inexpensive to manufacture which explains the price difference. The closet you can get are 21.5" monitors that are 1920 x 1080 resolution. They all use TN panel tech, so they are pretty inexpensive.
