Enter for a chance to win a Ballistic Gaming Computer.
was looking to get this laptop http://www.newegg.com/Product/Prod [...] 6834157039 i would like to know pros and cons about it...new egg didnt have any reviews. any components on it that has problems, is it a solid system?
What are you going to use it for? Intel CPUs are generally a little bit better than AMD's offerings, but the Turion II will be fine for most people. The HD 4200 is also an integrated graphics card, so if you are looking to do any gaming you may want to consider a dedicated solution.
