Tom's Hardware > Forum > CPU & Components > Sound Cards > Surround Sound Balancing?
Forum CPU & Components : Sound Cards - Surround Sound Balancing?
I recently bought a set of Creavtive Labs speakers but the front ones are right in front of my computer while the rear ones are by my wall. Is their a way to use either software or hardware to balance the speakers so my rear set is loader then my front. As far as I can tell my speaker set has no builting way of adjusting them.
Sponsored Links
Open your sound volume control, set options playback properties to select all speakers you wish to display, then control volume how you wish.
<pre><font color=red>°¤o,¸¸¸,o¤°`°¤o \\// o¤°`°¤o,¸¸¸,o¤°
And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign</pre><p></font color=red>
Reply to RichPLS
or if you have a Creative sound card, run the Speaker Setup. makes it very easy to balance the speakers.
Reply to cookingfrags
There are 613 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
