Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Compaq Presario CQ50-225LA Power Problem It is Not turn on What Could be the Cau
Forum Laptops & Notebooks : General Laptops & Notebooks - Compaq Presario CQ50-225LA Power Problem It is Not turn on What Could be the Cau
I have a Compaq Presario CQ50-225LA that is not turning on...What could be the direct cause of the issue..
Sponsored Links
I take it you have it plugged in, correct? I had a compaq laptop a few years back where the internal psu took a crap, which based on your description, could be the issue. If this is the case, check your power cord going to it, i.e. does it have power and is the little light on the box turning on? If so, it is probably the psu, which depending on whether or not it is under warranty, I'd send it in to be fixed. If not, it may not be worth the repair cost to bring it to a computer repair shop.
Message edited by buwish on 11-06-2009 at 01:53:37 AM
------------------------------ -Kevin
Desktop: Q9400(stock,lapped,SpinTechQ)/Intel DP43TF/VTEK 4850(512)/8GB DDR2 800Mhz/X-Fi Titanium Pro/Liteon BD-ROM/Velociraptor/Windows 7 Pro 64-bit
Laptop: Toshiba Satellite (M305)/T6400/4GB DDR2 800Mhz/Windows 7 RC 64-bit (for now)
Reply to buwish
There are 674 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
