Closed Solved
Radio shack hdtv antenna
I have an HDTV and I just disconnected from cable, I moved. Now, I cannot get a picture. I was told to get an HDTV antenna and I have one, now I can only get 1 station, from Mexico.
What's going on?
4 answers Last reply Best Answer
More about radio shack hdtv antenna
  1. Best answer
    Do you live within sight of a large city or in the country ?
    If in or near a city you should be getting several stations.
    Try rescanning the channels. Make sure the Tv is set to AIR and not cable.
  2. Suggest you go to http://www.antennaweb.org/aw/welcome.aspx, click on the Choose an Antenna button, and fill out your address - the app will tell you where & how far away the digital OTA station antennas are located, and what kind of antenna you'll need for receiving them.
  3. Best answer selected by migara.
  4. This topic has been closed by Mousemonkey
Digital TV HDTV Radio Connection Home Theatre
