CAN MY NTSC TVs BE USED WITH CABLE OR SATELLITE IN IRELAND
Hello,
i AM MOVIN TO IRELAND AND I WANT TO TAKE MY TELEVISIONS WHICH ARE ALL NTSC SYSTEM. AS MOST WILL KNOW IRELAND AND MOST OF EUROPE USE THE PAL SYSTEM. I HAVE CONTACTED A CABLE COMPANY AND A SATELLITE PROVIDER IN IRELAND AND BOTH HAVE TOLD ME THAT IF MY TELEVISION HAS HDMI INPUT OUTPUT CONNECTOR PORTS THEN I SHOULD BE FINE. THEY HAVE SAID THAT THE ONLY WAY MY TELEVISION WILL NOT WORK IS IF I AM NOT GETTING CABLE OR SATELLITE SERVICE AND WILL BE JUST WATCHING LOCAL/NATIONAL TV WHICH IS STREAMED OVER A PAL TUNING SYSTEM. I NEED A TECHNICAL MINDED INDIVIDUAL TO TELL ME IF THIS IS TRUE AS I HAVE 3 TELEVISIONS I WANT TO TAKE WITH ME: 55" TOSHIBA MODEL 55ZV650U, 32" SONY BRAVIA MODEL KDL-32S3000 AND A 52" SHARP MODEL LC-C5255U. ALL HAVE HDMI AND HDTV OUTPUT PORTS.
3 answers Last reply
More about ntsc cable satellite ireland
  1. I JUST FOUND SOMETHING INTERESTING. Atlona CDM-660 is a Pal to NTSC and or NTSC to Pal Digital converter.
    I hope this helped someone. I have not tried it yet but will be ordering one to see if it will works when i am fully settled. If anyone has tried this product and it did not work please let me know.
    The website says:
    You can take your NTSC American TV, VCR/DVD overseas or bring your PAL or SECAM TV VCR/DVD to the USA. Using the high quality conversion quality of the Atlona CDM-660 to convert TV signals you can use any PAL or NTSC TV to view any type of broadcast signal in the world.
    No video delay. Real Time video Conversion
    Use your PAL/SECAM equipment in a NTSC country and NTSC equipment in a PAL country
    Very easy to use, one time set-up no addition action needed
    Uses a standard AV or S-Video connection to convert any input signal to any specified output source
    Recording in permitted from any of the outputs. You can take advantage of making copies out of devices which are plugged in. Most of the DVD movies and VHS tapes
    Crisp and clear converted video. Latest video correction technology. You will even get better results on your video by using the CDM-660
    Dimensions: 9.3"(W) x 5"(D) x 1.8"(H)
    System condition memory. Converter remembers settings and returns to same input and output settings when turned back on
    LED Lamp shows current input and output video signal
    Detects input manually between: All Pal, All SECAM, All NTSC systems
    Universal power adapter, which will work in any country in the world; comes with European power adapter
    Built-in Colour Bar
    6mb field memory
    Input Signal: NTSC, N4, PAL, PAL M, PAL N, Secam
    Output Signal: NTSC 3.58, PAL
    Sampling Frequency: Y: 13.5 MHz; R-Y: 6.75 MHz; B-Y: 6.75 MHz
    Digital Code Bit: R G B: 8bits
    Line: 525 = 625
    Field: 60 = 50
    Memory: 6 mb
    DC: 9V 500mA
    Dimensions: (9.21" in.) W x (1.65" in.) H x (5" in.) D
  2. I think you will need to convert PAL to NTSC
  3. Hi
    Did you resolve this issue?
    is your US tv with NTSC system working in ireland?
    If yess, how? via HDMI or SCART or any other way???
HDTV TV Cable Home Theatre
