I am having printing with my wireless set up. Had it going before it just stopped working. Running Vista on both systems have the software installed just getting an error and is not printing from the comp I am running wireless. did a search for the print spooler and found nothing any suggetstions
I think you should check for supported drivers. Some times it well installed but not work properly. At that time uninstall it and reinstall it.
