Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsupdate,microsoft.public.windowsxp.newusers,alt.os.windows-xp (More info?)
Read if you have Wga problems with legal Preinstalled system.
Sorry for the multiple post.
Don’t not do this in safe mode!
Make sure you do this from an administrator account
Connect to the internet
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
In the left pane, locate and then click the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current
Version\WPAEvents
In the right pane, right-click OOBETimer, and then click Modify.
Change at least one digit of this value to deactivate Windows.
In the run box, type the following command, and then click OK.
%systemroot%\system32\oobe\msoobe.exe /a
Click Yes, I want to telephone a customer service representative to
activate Windows, and then click Next.
Click Change Product key to key on your machine.
Type the new product key in the New key boxes, and then click Update.
If you are returned to the previous window, click Remind me later
DON’T reboot.
Chose internet than activate. You will need to allow connection from
your firewall.
And you will see this message.
Windows is already activated. Click OK to exit.
reboot
You should then be able to validate windows. I tested this on w2040
emachine and it worked.
On Sat, 30 Jul 2005 11:38:35 +0200, fermu
<fmrioperez@BORRAME.terra.es> wrote:
>**/How to change the Volume Licensing product key on a Windows XP
>SP1-based computer
>http://support.microsoft.com/?kbid=328874#3
That what I based it on. However, if you reboot according to those
instructions, you won't be able to activate it.
My instruction show changing a legal volume license key to a legal oem
key.
Another note, keys do get messed up during install. So, if you have
a problem with wga and you legally installed windows and it was
activated. Then follow my key instructions except use the key you
installed xp with or the key that was provide by microsoft if you had
to call in to activate due to hardware changes.
> Don't not do this in safe mode!
> Version\WPAEvents
> DON'T reboot.
> your firewall.
> reboot
> Greg R
Hmm. I seem to remeber that MS disabled Major OEM Product Keys from
being activated of the internet!
Peace!
Kurt
Self-anointed Moderator
microscum.pubic.windowsexp.gonorrhea
http://microscum.com/mscommunity "Trustworthy Computing" is only another example of an Oxymoron!
"Produkt-Aktivierung macht frei"
On Sat, 30 Jul 2005 09:39:56 -0400, "kurttrail"
Yes Kurt you are correct in part.
I think that only with windows xp first release. You can still call in
and get a new key after some hassle with Microsoft.
The preinstall system use a hidden key given to them by Microsoft.
That key won't activate becuase it a volume license key. No need for
activation. However, wga is causing some problem with this as I have
read in newsgroups. The key on your machine should work and should
be able to be activated except maybe for the first release of Windows
xp.
I have also read. People are having problems now with wga for legally
installed products. So the key fix should work for them as well.
But either use the key you installed xp with or the key microsoft
gave you for any hardware changes you might have done.
> xp.
> If you got the key from Microsoft use that key.
> Greg Ro
You shouldn't go messing around changing keys, especially if you have XP
pre-installed by a major OEM, without finding out what they think about
it.
The hassle, the likelihood of having problems, and the risk involved in
not getting phone activated by MS is not to be taken lightly.
Peace!
Kurt
On Sat, 30 Jul 2005 15:01:22 -0400, "kurttrail"
>> xp.
>> Greg Ro
>it.
Kurt what the difference in using the key on the back of your machine
for reinstalling the operating system than using it for changing the
key? I see no difference. Except you have to activate it immediately
because it becomes on oem installation for those computers that have
been preinstalled.
They key on the machine is allowed to be used by me unless I sell the
computer.
Who cares what the oem company thinks especially if it is out of
warranty. It is my machine not emachine, not microsoft.
Do you have a better idea for people have that have problem getting
wga validation that have legal installed operating system--So, they
can still use windows update?
>>>> from being activated of the internet!
>>> in and get a new key after some hassle with Microsoft.
>>> for activation. However, wga is causing some problem with this as
>>> I have read in newsgroups. The key on your machine should work
>>> and should be able to be activated except maybe for the first
>>> release of Windows xp.
>>> legally installed products. So the key fix should work for them
>>> as well. But either use the key you installed xp with or the key
>>> microsoft gave you for any hardware changes you might have done.
>>> Greg Ro
>> have XP pre-installed by a major OEM, without finding out what they
>> think about it.
>> in not getting phone activated by MS is not to be taken lightly.
> been preinstalled.
Well with major OEM installs, you not suppose to have to activate.
F*#king around with changing PK's is just asking for worse problems than
WGA.
> computer.
Well, if you own a emachine that says alot.
Yeah, don't use it. Without WGA, Windows Update added an extra layer of
code that could go wrong with the patching process. With WGA, it added
yet another layer of BS on top of that!
People need to learn to cut up that BS code between them and installing
security updates.
Peace!
Kurt
Archived from groups: microsoft.public.windowsxp.general (More info?)
(No need to keep multi-posting)
I do agree the wga is becoming a major pain as there is a lot of
problems reported.
I never said emachine was a problem. I just tested it on an emachine
and it worked. I have a ghost image backup. I usually always test
stuff out before giving advice if applicable. I think this sound
advice. Microsoft may even give the same advice I am giving.
Business that do not have volume or corporate license have already
reported trouble getting update because wga didn't Validate, Some
with volume licenses are having trouble and the javascript bypass code
no longer works.
Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsupdate,microsoft.public.windowsxp.newusers (More info?)
On Mon, 1 Aug 2005 13:41:28 -0700, "Steve P"
>> Greg R
>I do have WGA problems with a legal preinstalled system, but am leery of
>trying undocumented advice. Is this a MS recommended fix?
They have not came out without any official statements. I don't know
if Microsoft is aware of the wga problems. They may be working on a
fix. If nothing happens after a week. Then I would write or call
Microsoft local office and ask them when are they going to fix wga
problem? These are just temporary workaround I mentioned that may
or may not work. In the meantime you could also use
http://help.bixfix.com until Microsoft fixes the problem. They
provide them with direct links to updates. Should get most updates.
I bet bigfix will eventually require wga for windows xp unless
Microsoft scraps the wga idea.
MS knows about the problems and they don't give a rat's ass about them.
I'd be willing to bet that they are harder at work closing all the
loopholes in WGA, than fixing the different reasons that people are
wrongly denied validation.
Peace!
Kurt
On Mon, 1 Aug 2005 19:45:37 -0400, "kurttrail"
>MS knows about the problems and they don't give a rat's BEEP about them.
I think Microsoft,bigfix, and oem companies have a contract with each
other to provide direct downloads for bigfix customers. Bigfix has
been preinstalled in lots of computers and has been around for years.
That why I mentioned it.
They better fix the problem if they don't want a class action lawsuit
or several small claim court actions. I am pretty sure Microsoft is
not that dumb to tick off legit paying customer. If they really can't
fix it. I am sure Microsoft will dump it. You do got to get them
time to fix stuff Kurt.
There are other workarounds out there but I can't mention them here.
They would not call it a workaround. Bigfix is different and is
legal.
>>> know if Microsoft is aware of the wga problems. They may be
>>> working on a fix. If nothing happens after a week. Then I would
>>> write or call Microsoft local office and ask them when are they
>>> going to fix wga problem? These are just temporary workaround I
>>> mentioned that may or may not work. In the meantime you could
>>> also use http://help.bixfix.com until Microsoft fixes the
>>> problem. They provide them with direct links to updates. Should
>>> get most updates. I bet bigfix will eventually require wga for
>>> windows xp unless Microsoft scraps the wga idea.
>> them.
> legal.
> Greg Ro
Give them time to fix what will never do me any good? Why the F*#K
would I want WGA in the first place working or not?
Since WGA does absolutely NOTHING for me, MS should have made GOD DAMNED
sure that it was working BEFORE it was made mandatory!
Give them time to fix it! ROFL! Wait for Big Brother to fix his
chains!
Peace!
Kurt
On Tue, 2 Aug 2005 01:05:23 -0400, "kurttrail"
>>> them.
>> legal.
>> Greg Ro
No one really want WGA if some MVPS
They should of done this, however the now they now it need working
Yes, It takes time to fix problems.
If I read correctly. It going to get worse if the get wga working
correctly. The new Microsoft software and non microsoft software may
make sure you have a wga before installing. I could be wrong. I am
waiting on another reply. It will also require dotnet installation.
>>>> them.
>>> each other to provide direct downloads for bigfix customers.
>>> Bigfix has been preinstalled in lots of computers and has been
>>> around for years. That why I mentioned it.
>>> lawsuit or several small claim court actions. I am pretty sure
>>> Microsoft is not that dumb to tick off legit paying customer. If
>>> they really can't fix it. I am sure Microsoft will dump it. You
>>> do got to get them time to fix stuff Kurt.
>>> legal.
>>> Greg Ro
Because it is worthless to the enduser. Why are you being patient about
giving MS time to fix something you won't ever need?
MS is like a baseball owner demanding to renegotiate a contract with a
player that ain't performing well.
Did you agree to WGA when you accepted the XP EULA?
MS is a bunch of double-dealing scumbags!
I was being facetious.
MS KNEW how flawed WGA was, and should never made it mandatory in the
middle of the XP lifecycle.
..NET is pretty funny. MS has said that Security Updates won't be
affected by WGA, though on Windows and Microsoft Update it is. MS has
stated that WGA is for addons, but the .NET addon [.NET is certainly NOT
a security update] does not required WGA to download!
MS is so goddamned arbitrary about what it considers an addon!
Peace!
Kurt
