Well this is what happened, I wake up one morning to find that my monitor is not turning on. I had turned it off properly the night before. Well I figured maybe it was just the power cord. Made sure it was connected right.
But no use, then I decided to hook up my old CRT monitor to see if it wasnt the actual monitor. But the CRT worked fine. (thats what i'm using rite now)
Anyway, I opened it up to see inside even though I know nothing about LCD Monitors. I looked around, made sure the wires were connected and everything. Made sure the actual power button was ok. And when I put it back together, IT WORKED!!!!
Now while I was hooking it up, I accidentally pressed the power button, and WALAAA! it turns off and now were back to scratch.
