Archived from groups: microsoft.public.windowsxp.general (More info?)
Not sure if this is a MB problem or a Windows XP problem. The problem is
that when booting this system (on a 3-client LAN) on 28 July, all kinds of
problems were experienced--no Internet connection, couldn't talk to the
router, some programs would not work, and so on. I have conducted 2 days of
experimentation so far like replacing the boot drive, restoring recent drive
images, re-flashing the BIOS, re-installing LAN "card" drivers, and probably
a bunch of other troubleshooting procedures I have since fogotten.
The weird thing is that if I change the system date in Windows or in the
BIOS setup back to 27 July or earlier, the system works fine. When I change
the date back to a date greater than 27 July, the problems return.
I checked the system with the latest (28 July) NAV def files, and also with
AntiVir--nothing found. Checked for spyware using Pest Patrol and Ad-Aware.
PP found one item called Actual Spy--removed that. Ad-Aware found an item
called WEBHANCER which I removed. This had no effect on the problem.
As long as the date on this system is set at greater than 27 July, it cannot
access the Internet through the router/DSL modem, and the other problems
mentioned above are experienced. Funny thing is that this system can
communicate with the other clients on the LAN. I completely redid the
router-client setup from scratch and that did not correct the problem with
this system. The other clients are working perfectly with Internet
connection and no problems.
Appreciate any ideas, 'cause I'm about to replace the whole stinkin' system
and the router if I can't find the cause of this problem soon.
Thanks, Larry
Three client LAN
This particular system is:
ASUS P4B533-E MB (BIOS 1014e--latest non-beta BIOS)
2.4 GHz P4 CPU
1 GB memory
2 large HD's
On-board Intel PRO/100 VE Ethernet
LinkSys BEFSR41 Router (using embedded DHCP)
1.5 mbps DSL
"Larry Roberts" <Lmroberts@earthlink.net> wrote in message
newseLGe.7302$6f.5769@newsread3.news.atl.earthlink.net...
of
drive
probably
change
with
Ad-Aware.
cannot
system
> and the router if I can't find the cause of this problem soon. >
> Thanks, Larry
> Three client LAN
> 2.4 GHz P4 CPU
> 1 GB memory
> 2 large HD's
> 1.5 mbps DSL
> Windows XP Pro SP2 and all updates
Have you tried running all that scanning in "safe mode"? -- there
are a number of "thingies" that can mask themselves but show
up in safe mode. It certainly has the smell of some sort of
malware - especially since no one else seems to be reporting
it. On the other hand, maybe the "Thursday bit" is set -- I have
seen that also -- no good explanation for whatever it is.
Make sure you run your scans in safe mode. You might also
try a different scanner like Trendmicro or others.
Worms, trojans and virus's can sit quietly on your computer and trigger on a
designated date, or on the same day each month.
Install a good firewall - one that blocks unwanted outbound traffic as well
as unwanted inbound traffic. Then when something tries to connect, out of
the ordinary, you will be flagged. At that point you can disallow that
particular instance either once or permanently. A good FREE firewall is
available here:
http://www.zonelabs.com/store/cont [...] btopnav_za
Then check you system for infestations of viruses, spyware, dialers, key
loggers etc.
Download, install, update and run the following from *safe* mode:
Don't ever go clicking things just because a web site, e-mail, popup or
rogue desktop tells you to! If you are not 101% certain what an action will
do - don't perform that action. Control your clicking finger!
Regards,
Richard Urban
Microsoft MVP Windows Shell/User
Quote from: George Ankner
"If you knew as much as you thought you know,
You would realize that you don't know what you thought you knew!"
> of
> drive
> probably
> change
> with
> Ad-Aware.
> cannot
> system
> Thanks, Larry
> Three client LAN
> 2.4 GHz P4 CPU
> 1 GB memory
> 2 large HD's
> 1.5 mbps DSL
"Mike Fields" <spam_me_not_mr.gadget2@comcast.net> wrote in message
news:eHSo82QlFHA.3380@TK2MSFTNGP12.phx.gbl...
of
> of
> drive
> probably
> change
> with
> Ad-Aware.
item
> cannot
with
> system
> > and the router if I can't find the cause of this problem soon. > >
> > Thanks, Larry
> > Three client LAN
> > 2.4 GHz P4 CPU
> > 1 GB memory
> > 2 large HD's
> > 1.5 mbps DSL
> mikey
Thanks for the ideas Mikey. I will run some scans in Safe mode. I would
agree that it looks like the work of some sort of bad guy, but I have been
unable to discover what. As I mentioned, I run NAV with updates installed
automatically, and also run a couple of anti-spyware programs in real time,
and periodically so it would be strange if something got by those. In
addition, I ran an on-line TrendMicro check and nothing was found. But I'll
give safe mode a try.
Can you explain what you mean by the "Thursday bit" may be set? I suspect
that could be related to the problem. I did a Drive Image Thursday (27 Jul)
about 7:00 PM and I guess that could have messed up a date bit. Reason I
think that may be involved is that I can change the system date/time to 27
Jul/12:00 and the system works fine. If I change it to 27 Jul/ 20:00, the
problems return. If you can elaborate on how I can check for the "bit"
problem, that would be very helpful.
Thanks for the suggestions Richard. I am running NAV which is updated
automatically. I run Zonealarm Pro, SpywareBlaster and PestPatrol in
real-time. I run Spybot S&D, and Ad-Aware manually periodically. In addition
to NAV, I ran a check with AntiVir and did an on-line scan at TrendMicro.
Nothing has been found.
As Mikey suggested, the problem may have to do with a mis-set date bit
somewhere. If you read my reply to him you will see why I say that. If you
have any ideas relating the date bit possibility I would greatly appreciate
it.
Larry
"Richard Urban [MVP]" <richardurbanREMOVETHIS@hotmail.com> wrote in message
news:uURgV3QlFHA.1444@TK2MSFTNGP10.phx.gbl...
a
well
> available here:
http://www.zonelabs.com/store/cont [...] btopnav_za >
> loggers etc.
> If you don't have any antivirus installed, AVG Antivirus (free) from
> http://free.grisoft.com/doc/2/lng/us/tpl/v5 >
> Ad-Aware (free) from http://www.lavasoftusa.com/software/adaware/ >
> SpyBot Search and Destroy (free) from
> http://www.safer-networking.org/en/download/index.html >
> Microsoft Anti Spyware (free) from
> http://www.microsoft.com/athome/se [...] fault.mspx >
will
> Regards,
> Richard Urban
of
> > of
> > drive
> > probably
> > change
> > with
> > Ad-Aware.
item
> > cannot
with
> > system
> > Thanks, Larry
> > Three client LAN
> > 2.4 GHz P4 CPU
> > 1 GB memory
> > 2 large HD's
> > 1.5 mbps DSL
For those following this thread, this is what was causing this problem.
Unfriggin' believable!! Three wasted days to diagnose this problem. It will
be a cold day in Hell before I install any APC or Sun software again.
Java Runtime Environment expiration
Problem Summary
In order for PowerChute Business Edition to remain functional, users must
upgrade to any version of 7.x. Due to expiration of the Sun Java Runtime
Environment certificate, versions 6.x of PowerChute Business Edition will
cease to operate normally as of July 27, 2005. Failure to upgrade will
result in PowerChute Business Edition no longer providing monitoring and
graceful shutdown of your system.
Impact
Customers running PowerChute Business Edition 6.x after July 27, 2005 will
have the following experience: When a power event occurs, such as a power
failure, PowerChute Business Edition will perform a graceful shutdown. When
power is restored, the UPS will reboot and the Operating System will be
restored. At this juncture, the PowerChute Business Edition service will no
longer provide monitoring and graceful shutdown of your system. Users must
upgrade to PowerChute Business Edition 7.x.
of
drive
probably
change
with
Ad-Aware.
cannot
system
> Thanks, Larry
> Three client LAN
> 2.4 GHz P4 CPU
> 1 GB memory
> 2 large HD's
> 1.5 mbps DSL
You would think that they (APC) would send e-mail's to all registered users,
wouldn't you?
Regards,
Richard Urban
news:TdnHe.1265$ns.1110@newsread1.news.atl.earthlink.net...
> will
> Problem Summary
> Impact
> When
> no
>> of
> of
> drive
> probably
> change
> with
> Ad-Aware.
> cannot
>> with
> system
>> and the router if I can't find the cause of this problem soon. >>
>> Thanks, Larry
>> Three client LAN
>> 2.4 GHz P4 CPU
>> 1 GB memory
>> 2 large HD's
>> 1.5 mbps DSL
They did for me!
And it is not "truly" APC's fault, since they rely on Sun's Java run-time
modules.
news:%23cdimiolFHA.2152@TK2MSFTNGP14.phx.gbl...
> users, wouldn't you?
> Regards,
> Richard Urban
>> will
>> Problem Summary
>> Impact
>> will
>> When
>> no
>> must
>>> of
>> of
>> drive
>> probably
>> change
>> with
>> Ad-Aware.
>>> item
>> cannot
>>> with
>> system
>>> and the router if I can't find the cause of this problem soon. >>>
>>> Thanks, Larry
>>> Three client LAN
>>> 2.4 GHz P4 CPU
>>> 1 GB memory
>>> 2 large HD's
>>> 1.5 mbps DSL
