Do you connect input to input or input to output from several devices?
Last response: in Home Theatre
Outputs to Inputs:
Depending on distance coax cable is probally the best way to go.
You need a dvd player with a coaxial output. Cable out of DVD player to a coax splitter. Run a cable to each TV
Without coax you'll need a splitter/amp to take signals from DVD player and send them to the TV's.
The logistics all depends on what your DVD outputs are, and what inputs your TV's have.
Ask the community
