Os problem
G
Guest
Guest
Hard disk failure ?
I think you need to supply a little more detail.
alexinnes
136
Hey there are a number of problems that can stop the OS from booting. If you provide more details on the problem, e.g. what is it doing on boot.
I know it sounds silly but its always good to check that all the cables inside your case are properly pushed into hard drives etc
