G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I'm upgrading an 802.11B network to 802.11G, and I'm stuck on an
Inspiron 8200 with a TrueMobile 1180 card, which not only only does
802.11B, but doesn't appear to support WPA. [I'm running the 'latest'
drivers, as there's only one set, A00].
What are my options, replace the MiniPCI card with an 802.11G card
that comes with WPA drivers? Any reccomendations?
Thanks!
G
Guest
Guest
<William P. N. Smith> wrote in message
news:pbagj1h7jl2mtv81vhh7blcl7anmii1qak@4ax.com...
> on an
> only does
> the 'latest'
> 802.11G card
> Thanks!
Have a look here;
http://accessories.us.dell.com/sna/productlisting.aspx?c=us&l=en&cs=04&category_id=5823&first=true
It would appear that the 1450 will do what you want. WPA and
b/g. There also are a bunch
of PCMIA card type modules.
G
Guest
Guest
Yeah, but it doesn't list the 8200. Is it still likely to work? It
lists the 8600, but I'm afraid if I don't get the right one that (for
instance) the antenna connectors will be wrong, and then I'll look
like a real idiot... 8*)
Thanks!
G
Guest
Guest
If you check the specs for the 1180 vs. the 1450 you
will find they are physically the same.
news:42lgj1lr14r9ephi0rjn8pf7f6656g8pd1@4ax.com...
> work? It
> one that (for
> I'll look
> Thanks!
G
Guest
Guest
Thanks, guys, I've got one on order. They patched me thru to parts
sales (yikes!) who assured me that it would fit. I then placed the
order online. I'll let you know!
Thanks!
G
Guest
Guest
> Thanks!
I'd guess they're pretty standard connectors. Look at buy.com or
zipzoomfly.com. You can buy a mini-pci G for under $30. Worth the gamble.
Tom
