Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > [Solved] LCD monitor settings
Forum Computer Peripherals : Flat Panels/ LCDs - [Solved] LCD monitor settings
Best answer from Strangestranger.
Hello. Unfortunately I have no idea if this is the best place to post but I'll try my best.
I have recently bought a LCD monitor (LG W1942T if it matters). It works great, except when I load this http://www.lagom.nl/lcd-test/clock_phase.php LCD test I get horrible "stripes" while scrolling. It resembles this image: http://www.lagom.nl/lcd-test/img/c [...] rong-1.gif
Now the website recommends setting clock/phase properly. By default they are both set on 50. The stripes disappear when I set phase to 90. Is it safe to change phase? I am afraid I'll damage my monitor or something by changing phase so dramatically? Help would be appreciated.
If it damaged your monitor the manufacturer wouldn't put the option there without at least a warning or they would be sued to hell.
Do you not have a DVI connection you can use? Generally don't have to bother with those settings using a digital connection.
Sponsored Links
Best answer
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to Strangestranger
Well, I do have a DVI connection I can use, but it doesn't help anything. Only thing it changes is locking the clock/phase settings, but I still get that "stripes" effect. I found out that only way to take care of it is connecting via D-Sub and configuring the phase.
Reply to jacek90
There are 800 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 demondrumer won the Freshman badge
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
