G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Please can someone help?
I'm using a USB enclosure to add a 160Gb HDD to my computer. Sometimes, the
drive is not recognised at all, but even when I can get Windows XPHome to
eventually show the drive in My Computer, I can only access it for about ten
minutes. After this time I get a Write Failed error message, if I try to save
anything to it.
I have tried the drive (a Maxtor DiamondMax) as master, slave, or cable
select, but no luck.
Looking through this help group, I found one recommendation to delete the
USB ports and reinstal them. How do I do this, please?
My machine has AMD 2400+ 2Gb with 1024Mb RAM. Hope this helps.
Thanks in anticipation.
anything to it.
