Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > Best Aspect Ratio for 24" monitor
Forum Computer Peripherals : Flat Panels/ LCDs - Best Aspect Ratio for 24" monitor
After years of using s 19" screen im going to treat myself too a 24" screen however, I am a bit confused by aspect ratios. I use my pc mostly for gaming and work, not movies. Which is better for my needs, a 1920×1080 or 1920×1200 screen?
Any help or advice would be of great help. Thanks in advance.
Message edited by MrBread on 07-20-2009 at 11:40:15 PM
Sponsored Links
I prefer 16:10 just because I can see more on the screen.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
The real question is how much money do you want to spend?
Reply to jaguarskx
- 0 +
With regard to money im looking to spend about £250 pounds although I could stretch if the screen was perfect. What I really want to know is, which resolution if better for gaming, especially since i play quite a lot of older games.
Reply to MrBread
Since 16:9 monitors have about 11% less pixels than 16:10 monitors, you can expect maybe a 8% - 10% increase in gaming performance generally speaking.
Depending on how "old" you are talking about some games may be able to be played on a 16:9 monitor. For example, Far Cry came out back in 2003 I think, but I was able to play it at 1920 x 1080 on my Asus VK246H monitor. Games like Diablo 2 will stretch to fill the entire screen unless you play it in a window or if the monitor allows to to set the Aspect Ratio (which tries to fill the entire screen without stretching the graphics; black bars on left and right).
Reply to jaguarskx
There are 1209 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
