Headphone Jack Problem.
MMarroquin1024
25
The problem is quite simple... When you plug your headphones into a laptop , the integrated speakers should be disabled, right?
Well, this laptop's integrated speakers don't (and it's really annoying). I don't get the usual message indicating that a jack has either been plugged or unplugged. I do get the message from the mic jack though, so I don't think that this is a software issue.
My question is: is there any way I can disable the integrated speakers permanently?
Laptop info:
ASUS F50S
Windows Vista Home Premium
Realtek HD Audio
Please Help...
Thanks.
luketmosley
