Solved
Universal remote control TV and PC!
Is it possible to find a universal remote that will control a Television and a Computer? i.e. Turn on TV, adjust volume or input AND control media on the PC without using one of those super expensive Logitech harmony remotes? If you know of one, por favor tell me! linx help as well (newegg, tigerdirect etc...)
2 answers Last reply Best Answer
More about universal remote control
  1. Best answer
    Compare $25.99
    Check this one at best buy, the link will only work for a minute or two:
    http://www.bestbuy.com/site/TV-Video-Accessories/TV-Remote-Controls/abcat0107039.c?id=abcat0107039
    Sony - 8-Function Learning Remote
    Model: RMVL600 | SKU: 7689156
    Controls 8 A/V components; compatible with most major brands; on-screen menu operation for DVD and VCR
  2. Best answer selected by tu_illegalamigo.
HDTV TV Computer Home Theatre
