Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > [Solved] High-end system, need a monitor
Forum Computer Peripherals : Flat Panels/ LCDs - [Solved] High-end system, need a monitor
Best answer from strangestranger.
I'm building a high-end system that i plan to use for some fairly serious gaming, along with web design (photoshop, dreamweaver, etc..) an i need a monitor. I'm thinking about 24-30 inches, and would rather not spend more than $200, but i'll spend more if i have to. Anyone have any suggestions about a good monitor? Also, what size is ideal (i.e. is a 30" monitor too big for desk use?)
Thnx!
I don't know if you would want a TN panel seeing as what you want to do with it.
I recently took possesion of a HP 2475W to replace my dell 2405fpw which I gave to my parents.
The 2405FPW itself is very good but not as good as the HP in colours or responsiveness at least using something like the online LCD tests.
The one suggested above, the 2408wfp is also a good choice and I nearly went for it.
If you were a gamer who favoured speed over anything else then a cheap tn panel may have, and it is only a may, been your best choice but the mention of other things I would think would rule out a cheap display.
True I am a gamer myself but even I do not like TN panels despite their claimed speed advantage.
Sponsored Links
Well, a 30" is out of the question, unless you meant to type $2000 instead of $200. For accurate color and a stunning display, this is on sale right now and is a great buy, but well out of your price range: http://accessories.us.dell.com/sna [...] u=320-6272
Otherwise, I'd go for something like this: http://accessories.us.dell.com/sna [...] u=320-7956
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
Best answer
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
I don't know... After reading the reviews for both, the more expensive 2408 seemed to have more problems than the far cheaper G2410...hmmm. That just preliminary research, but the G2410 seems to be a very nice product.
Reply to L3v14th4n
What's more important gaming or color accuracy?
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
I have a 2408WFP, and I love it. It's a gorgeous monitor, and well worth the money.
Reply to cjl
Both, really... but probably gaming
Reply to L3v14th4n
I have no recommendations at your price level.
Reply to jaguarskx
BEFORE YOU BUY!!!
I have been watching for awhile now on a new monitor i would like to buy. these are some of the ones i have been looking at from the 200-300 price range and 23+ inches only widescreen hdmi 1080 etc.
This is a hanns-g bigger model 28". its solid but older lot of connections. read more if you like.
http://www.newegg.com/Product/Prod [...] 6824254026
here is a nice asus, only 21.5" full 1080. lots of input connections.
http://www.newegg.com/Product/Prod [...] 6824236051
NOW if i had to buy a monitor right now on the spot based on price/proformance and brand this would be it.
http://www.newegg.com/Product/Prod [...] 6824005125
lg 23" widescreen. great contrash ratios(something to watch tho as backlight led monitors are coming)
lots of connections. 1080. get response time 2ms. 200bucks. you get a lot of bang for the buck here.
Reply to Lockie85
There are 960 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
