Sound problem
Forum Computer Peripherals : Other Peripherals - Sound problem
There is sound problem in my computer. I tried speaker as wel as headfone but no result, i have installed drive and in device manager i checked there is no yellow color exist in sound section... Please help
Sponsored Links
control panel-->sound-->audio tab-->do you have a default audio device selected?
Check the volume control and make sure it's not muted and turned up.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
Yes default audio device is selected. It is something like 3-media...
Reply to mehullotwala
- 0 +
Are you plugging the speakers into the right port? It's usually a green one.
Reply to aford10
- 0 +
Yes I have tried all the ports including green one
Reply to mehulc
- 0 +
Do you use an add on sound card or onboard sound?
Check the BIOS to see if audio is enabled. Probably under the integrated peripherals section.
Reply to aford10
Tom's Hardware > Forum > Computer Peripherals > Other Peripherals > Sound problem
There are 1266 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
