TV component and satellite box with composite issue.
Last response: in Home Theatre
From the box I had red, white, and yellow in their corresponding plugs. On the TV I had red and white audio plugged in red and white audio, and the yellow was plugged in green slot that had a Y next to it.
Ignore the last post!
You have video but in black and white. The composite should be in color.
Is it possibly an adjustment that needs to be made to tv.
If you have a DVD player with composite can you see if that shows in color?
At least you'll know if it's the TV or sat box.
I have the exact same model TV in a different room and it is hooked to a DVD player, plays just fine. The connections, however, are different. The DVD player has a component connection just like the TV.
Ask the community
