TECH: Williams FLASH L.E.D. Question !!!!
Last response: in Video Games
Archived from groups: rec.games.pinball (More info?)
Hey Kevin,
It's not an LED display - they're gas plasma discharge. Much higher voltage
than LED's is the main reason I'm pointing that out : )
The problem is going to most likely be on your display controller board, which
is the lower left display on your machine. It could also be a connector problem
at that board, or at the connectors on the top edge of your MPU board (top left
board inside the backbox)
Read here for more info: http://marvin3m.com/sys37/index3.htm#display
Keep in mind several generations are covered here so not all the information
will match your machine. Flash is a system 4.
Richard
On 11 Jun 2005 11:14:48 -0700, kevinmarnib@earthlink.net wrote:
>I have a Williams Flash machine, and on the 3rd and 4th scoring LED
>display, only the top half of both are showing. How do I correct and
>do I need to replace the LED displays???
>Please advise.
>thanks for the help,
>Kevin
Ask the community
