Closed Solved
Power cord gets hot
Hello,
my power cord gets very hot, what is the problem
4 answers Last reply Best Answer
More about power cord
  1. latecia said:
    Hello,
    Is the power cord in a well ventilated area? Are you plugged into a surge protector? Is it the wire or the adapter unit?
  2. Best answer
    It generally means that the cord is not rated for the Amps that it is carrying. If the cord is even slightly warm to the touch, immediately replace it with a cord that has a sufficient Amp rating. Generally, thin skimpy lamp extension cords should not be used to power computers.
    Computer power cords should have a 15 Amp or higher rating.
  3. This topic has been closed by Area51reopened
  4. Best answer selected by Area51reopened.
Hewlett Packard Power Computers
