Yes No
Ads
Tom's Hardware > Forum > Home Audio > High-End Audio > Surround sound system help
Forum Home Audio : High-End Audio Surround sound system help
I'd like to get a new surround sound system, preferably below $800 including the receiver and speakers. Which is the best to get? I want to use them with, my consoles, blu-ray movies, and PC
Message edited by offspringfan23 on 02-06-2010 at 07:21:13 AM
Reply to offspringfan23
There's nothing that comes close to what the Take 5s provide at $200. Now if you increase your budget, there will be a lot more options.
Reply to astrallite
this looks like a great receiver:
http://www.amazon.com/Onkyo-TX-SR6 [...] 560&sr=1-1
I can spend a little over $900, this one is only $419.98 right now
Message edited by offspringfan23 on 02-07-2010 at 10:07:02 PM
Personally on a $900 budget I would recommend no more than $300 on a receiver, but if you are set on that receiver, I think I can squeeze in something for close to 1k. If you pick up the 507 instead of the 607 you can do it in $900.
507 for $320.
http://www.amazon.com/Onkyo-TX-SR5 [...] 890&sr=1-2
3 pairs of these:
http://www.bestbuy.com/site/Insign [...] &cp=1&lp=1
Hsu STF-1
http://hsuresearch.com/products/stf-1.html
Reply to astrallite
I've done some outside research, and so far these are the systems I'm leaning toward
http://www.amazon.com/gp/product/B [...] d_asin_lnk
or
http://www.amazon.com/Onkyo-TX-SR6 [...] 243&sr=1-1
with
which one would be better for everything (360 via component, Wii via component, PS3 via HDMI, Fios TV via hdmi, PC via hdmi and music)
Message edited by offspringfan23 on 02-12-2010 at 05:12:36 AM
There are 1550 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
