Sign-in / Sign-up
Network and Sound driver issues on Maximus IV Extreme
  • Drivers
  • Sound Driver
  • Audio
  • Windows 7
Last response: in Windows 7
October 10, 2012 6:52:55 PM
Hi guys, I have a huge problem!
I recently took my pc apart to clean it up a bit and well, when I put everything together again I can't get my audio and network drivers to install correctly.
I install my audio driver and I then reboot, but when it's restarted, the audio troubleshooter still tells me that I should install the drivers even though I just did?
Same with my network driver. I install my chipset driver and when I want to install my network driver afterwards it tells me that there are no chipset drivers present?
I've formated and installed windows twice and it still won't install the drivers correctly.
My specs:
Asus Maximus IV Extreme B3 Revision
8GB RAM
i7 2600k
nVidia ENGTX275 graphics card
1T HDD
Win 7 Ultimate 64bit
I've downloaded new drivers from the Asus website and it still won't install, I cant go on the internet and my audio doesn't work untill the drivers are working :( . I have no idea what to do or what caused this. If anyone have any ideas please share them! Thank you. :D
More about : network sound driver issues maximus extreme
a b $ Windows 7
October 11, 2012 7:59:25 PM
upload an image of device manager
m
l
a b $ Windows 7
October 11, 2012 8:02:26 PM
from this link
http://www.asus.com/Motherboards/Intel_Socket_1155/Maxi...
choose win 7 64 bit
then go down to lan
then download
Version 16.5.0.0
Description Intel Gigabit Ethernet Driver V16.5.0.0 for Windows 32/64bit XP & 32/64bit Vista & 32/64bit 7.(WHQL)
for sound
AUDIO (1)
Version 5.10.0.6254&6.0.1.6254
Description Realtek Audio Driver V6.0.1.6254 for Windows 32/64bit Vista & 32/64bit 7.
Realtek Audio Driver V5.10.0.6254 for Windows 32/64bit XP.
m
l
October 11, 2012 8:09:14 PM
No worries I found out that my motherboard reset the hard drives, network adapters and sound cards to disabled. Just had to enable them again. :D
m
l
