Tom's Hardware > Forum > CPU & Components > CPUs > I need help, system locking up
Forum CPU & Components : CPUs - I need help, system locking up
My computer will lock up when I play Asherons Call, and very rarely in Battlefield 1942. I just recently got my new Video Card(Gigabyte Raedon 9700 Pro), Mobo, Processor, and ram. I made shure EVERY driver is up to date...hell I even re-installed, but to no avail it still locks up. I cant alt-tab, Ctrl-x, Ctrl-Esc,or Alt-Ctrl-Delete either. It will lock up during gameplay while im trying to kill something. And for some reason I cant Alt-Tab out of the game because if I do this is what happens. I get back into windows but then it locks up after I click a few times trying to get into other screens. Could my motherboard be incompatable with my Videocard or my videocard have some kind of error, or is it the drivers? Ive run ram test software and thats not the case. Im at a loss for solutions, any info would help.
Thanks,
Ryan
2.53 P4
Intel D845GEBV2
Gigabyte ATI Raedon 9700 Pro
Creative Labs Audigy
768MB DDR 333
Viewsonic VX700-2 Monitor - DVI
Yamaha 44x Burner w/T@2 technology
<P ID="edit"><FONT SIZE=-1><EM>Edited by ryan_usmc on 01/04/03 04:43 PM.</EM></FONT></P>
Sponsored Links
Could it be a driver conflict?
hmmmm i really wouldn't know, but did you have installed a fresh windows system or not?
overriding drivers can mess up Windows (or WINBLOWS :D ) and then you can have strange hangs etc etc
if windows is freshly installed, then i would suggest to look at the ramdac temp (open the case, and when it hangs, you just feel the heat of your ramdac's) a friend of me encountered the same and he glued heatsinks on it, and the troubles were over...
otherwise, i wouldn't know, but he had the same gaphics card
Enosi and I....
Reply to Aidanoridania
Agreed, this does sound like an OS issue...
When using a Win9x system, the Operating System does not "like" it when you swap vid cards. The solution that works best (unless you know how to edit the registry) is to completely reinstall windows.
After that, then I would start chasing hardware solutions...
This post is guaranteed fresh for up to 7 days after the date printed on the box.
Reply to Groveling_Wyrm
Check your AGP settings. AGP driving strength, aperture, fast write, etc.
To start press any key. Where's the "any" key? --Homer Simpson.
Reply to Black_Cat
There are 513 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
