Best built internal tuner in flat screen HDTV
Hi there
I wonder if any one can tell me which flat screen HDTV, has BEST built in internal tuner ,
in terms of sensitivity and picture quality, for terrestrial signal.
I'm living in rural area and I want to make sure using good dip fringe antenna
I can pull good quality signal From 140- 160miles away , with out crazy amplification .
I decided to look at size of screen between 46- and 55 inches.
I don't really care how TV itself look like , I need good reliable guts in it .
I'M FIRST TIME BUYER , I will be really appreciate for advice.
Have nice day guys
Andy
1 answer Last reply
More about best built internal tuner flat screen hdtv
  1. all tuner roughly the same. If you worry about the weak signal; get a amplification antenna.
Digital TV Flat Screen Tuner HDTV Home Theatre
