Closed Solved
XP Audio Problems
Hello,
My audio has disappeared from my emachine. I can no longer hear sound and don't see any sound driver installed. I have my set up disks and was wondering, if I just install the first disk and reinstall the drivers will it mess anything up. Do I have to completely reinstall all 4 disks and loose my info. I don't know how to back up my computer first.
3 answers Last reply Best Answer
More about audio problems
  1. Best answer
    You just re-install your audio drivers only! You will get your sound back!
  2. Best answer selected by mousemonkey.
  3. This topic has been closed by Mousemonkey
Audio Windows XP
