Tom's Hardware > Forum > CPU & Components > CPUs > Blast fromm the past.. what speed though?
Forum CPU & Components : CPUs - Blast fromm the past.. what speed though?
Got an old AMD chip here out of a junk system.. Dunno what speed it is (might be destined for file sever use or shelfe space)
Am5x86 -P75
AMD-X5-133ADW
A 9633FPC
3.45v
Is it running at 75? or 133?
If the Scatman can do it so can you...
Sponsored Links
does it matter? lol
my computer is so fast, it completes an endless loop in less than 4 seconds!
Reply to jihiggs
just personal curiosity..
Its a classic, just I dont know much about it :smile:
Reply to Lonemagi
- 0 +
I don't have any references but I'm almost possibly sure it's a 486-class processor often sold from evergreen technologies as an overdrive processor. It runs at 133 and thusly has a Pentium P75 rating. You can easily get that sucker to run at 150 if you want P83 speed.
Dichromatic for your viewing plesure...
Reply to Schmide
they sell AMD cpu's like that?
Reply to Lonemagi
You have a genuine rare 586 processor and this was one of the fastest ever made! It was basically a very fast 486 and the last of its kind brought out by AMD before they upgraded to the K5 line which used a totally different socket. This chip will fit into a socket 3 which is the same one used by all 486 processors so if you have an old 486 motherboard try it! It probably won't work however unless the board is a fairly late model capable of running at least a 486DX4 100 overdrive. The chip runs at 133 MHz but is only equivalent to an old Pentium 75 in performance (which was around at the same time) hence the reason for the P75 rating. It was much cheaper to purchase however and gave late model 486 owners a cheap alternative to upgrading to the performance of a base model Pentium without having to change their motherboard. I had one in my early days of computing and loved it! It was able to run quite demanding games which you wouldn't have considered on a 486 and was very efficient as an office PC.
Check these sites for more info!
http://www3pub.amd.com/support/faqs/5x86faq.html
http://www.cpu-museum.de/?m=AMD&f=5x86
Reply to bronibbear
- 0 +
It's not that rare. I bought one for about $7 a while ago (more than a year). Put it in a tiny Data Book. Worked well at 150. Never uesd it since. It's bascially a 133dx4.
Reply to Schmide
Wow, reading some of this is like reading about household life before indoor plumbing was a social norm...lol
Thanks for the links..
Its a shame, a buddy of mine just trew out a board with an amd 8088 cpu on it. He tried to save it for me (Im trying to collect cpu's)but it shettered when he tried to break it off the board.
Oh well, just have to search those comps put to the curb! :wink:
Reply to Lonemagi
Quote :
Dude, AMD never made a 8088 compatible chip. Their first CPU was a 80386 clone.
<A HREF="http://forumz.tomshardware.com/community/modules.php?name=Forums&file=viewtopic&p=26708#26708" target="_new"> Go to my CPU Vendor Poll </A>
Reply to Spitfire_x86
I have two of these, and they are sort of rare. I'll be selling them soon on eBay. Like the other guys said, they're a 586-133. Basically it's a 486 with some feature added I think. And it's PR75 rated. Now, this is impressive give that the P75 used a 50MHz FSB and the 5x86 used a 33MHz FSB! But you can actually get PR100 performance if you have a board that supports the 50MHz bus speed and set it at 3x50.
They didn't just fit Socket 3, they also fit Socket2. Socket2 had extra pegs for the heatsink, in the same locations as Socket7, 370, and 462! So if you find a rare Socket2 board that supports 4x multiplier and 50MHz, using 5v (instead of 3.3v) core you can probably get the thing to run 4x50=200MHz, using an Athlon cooler!
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
Reply to Crashman
I refer you to the page that bronibbear had refered me to
<A HREF="http://www.cpu-museum.de/?m=AMD&f=8088" target="_new">Link</A>
<font color=green>::: Sir, I'd like to return this cpu, it is dead.</font color=green> <font color=blue>::: Its not dead, its resting...</font color=blue>
Reply to Lonemagi
Thanks for the link. But I never found anywhere else about AMD cpu's older than 80386 clone
There are 643 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
