Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > [Solved] Scratchy audio when monitor is active?
Forum Computer Peripherals : Flat Panels/ LCDs - [Solved] Scratchy audio when monitor is active?
Best answer from pmerritt.
Hi, I recently bought a philips2301e monitor. Problem is audio becomes scratchy when I scroll windows or generally when the monitor is "active". So audio is clean when the monitor is still, but becomes scratchy when I scroll web pages or use windows explorer, etc.
Is this interference caused by the monitor?
Could upgrading the audio cable correct this?
I should also mention that when gaming, with Team Fortress 2 at least, the audio is clean.
Message edited by Floyd442 on 09-19-2009 at 02:42:01 AM
you're probably using the onboard audio of your motherboard and it's not the monitor it's likely some poor shielding on the motherboard. If you purchased a dedicated soundcard that noise will probably go away.
Sponsored Links
Best answer
Reply to pmerritt
There are 1174 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
