Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > System Restore Has Stopped Automatically Creating System C..
Forum Windows XP : Windows XP General Discussion - System Restore Has Stopped Automatically Creating System C..
Archived from groups: microsoft.public.windowsxp.general (More info?)
For some reason System Restore has stopped automatically creating System Checkpoints. It
is turned on, and is set to use the Maximum amount of space for monitoring my C drive.
Yes, there is a great deal of unused disk space. I had used Disk Cleanup/ More
Options/System Restore Cleanup prior to the problem, only that one option, not any of the
other Disk Cleanup options. So, I have no earlier Restore Points to restore to, only the
ones which I have Manually created since.. The registry string:
RPGlobalInterval
for the registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore
has a value data of: 15180
System Restore will manually create Restore Points, and it will restore from them, and
undo the restores from them. But, it will no longer automatically create System
Checkpoints every 24 hours. I did not do a Windows Update prior to the problem, or not
install any hardware/drivers, and the only software that I installed was Kelly's
TaskbarRepairToolPlus!. Does anyone have an idea of what might be causing this? Please,
no useless replies from System Restore haters, saying that it is garbage. That is not
constructive.
T.C.
t__cruise@[NoSpam]hotmail.com
Remove [NoSpam] to reply
Sponsored Links
> System Checkpoints. It is turned on, and is set to use the Maximum
> amount of space for monitoring my C drive. Yes, there is a great deal
> of unused disk space. I had used Disk Cleanup/ More Options/System
> of the other Disk Cleanup options. So, I have no earlier Restore
> Points to restore to, only the ones which I have Manually created
> RPGlobalInterval
> restore from them, and undo the restores from them. But, it will no
> longer automatically create System Checkpoints every 24 hours. I
> did not do a Windows Update prior to the problem, or not install any
> causing this? Please, no useless replies from System Restore haters,
> saying that it is garbage. That is not constructive.
Double check to see if "task Scheduler" is turned on.
Every so often task scheduler on my system gets turned off (Idon't know
why),when this happens auto checkpoints no longer work.
Mike Pawlak
Reply to map
- 0 +
> RPGlobalInterval
> constructive.
> T.C.
http://bertk.mvps.org/html/srauto.html
Rock
MS MVP Windows - Shell/User
Reply to Rock
< inline >
> creating System Checkpoints. It is turned on, and is set
How much disk space is SR using to store restore points?
Is this true for all the drives/partitions SR monitors? Any monitored drive that falls
below 50mb's of free space will cause the deletion of all restore points.
>I had used Disk Cleanup/ More Options/System Restore
> any of the other Disk Cleanup options. So, I have no
> earlier Restore Points to restore to, only the ones which
Running Disk Cleanup with that option deletes all but the most recent restore points.
> RPGlobalInterval
That's the default, 24 hours.
> it will restore from them, and undo the restores from
> was Kelly's TaskbarRepairToolPlus!. Does anyone have an
> idea of what might be causing this? Please, no useless
As previously posted by Rock, take a look here of some troubleshooting tips.
System Restore fails to create an automatic restore points.
Regards,
Bert Kinney MS-MVP Shell/User
Reply to Anonymous
There is only one hard drive, the C drive being monitored, with no partitions, and there
are 25 GB free. The Task Scheduler Service is Started, and set at Automatic. None of the
trouble shooting at that web site seems to apply.
T.C.
"Bert Kinney" <bert@NSmvps.org> wrote in message
news:#ZfnuQUmFHA.3900@TK2MSFTNGP09.phx.gbl...
> < inline >
> > RPGlobalInterval
> Regards,
Reply to Anonymous
Hi,
Go to Start - Run and type eventvwr.msc and press enter.
Click on System in the left pane.
Click the gray title “Source” at the top of the source name column in the right pane to
sort by source name, look for "sr" and "srservice".
Double click on each of these events, then click on the button below the two arrows in the
upper right corner. This will copy the event information to the clipboard. Paste the
information for each of the two event here.
Regards,
> monitored, with no partitions, and there are 25 GB free.
> Automatic. None of the trouble shooting at that web site
> seems to apply.
>> < inline >
>>> set
>>> drive.
>> Any monitored drive that falls below 50mb's of free
>>> which
>>> RPGlobalInterval
>>> System Checkpoints every 24 hours. I did not do a
>>> Windows
>> points. http://bertk.mvps.org/html/srauto.html
>> Regards,
Reply to Anonymous
There are no listings for "sr," only "srservice," and those are all notes for each of my
successful manually created restore points, nothing else. They are self-evident, and do
not need to be copied and pasted to this post.
T.C.
news:#F1MUFVmFHA.3256@TK2MSFTNGP12.phx.gbl...
> Hi,
the
> Regards,
> > seems to apply.
> >> < inline >
> >>> set
> >>> drive.
> >>> which
> >>> RPGlobalInterval
> >>> Windows
> >> Regards,
Reply to Anonymous
- 0 +
my computer | properties | system restore tab
CHECK "turn off system restore on all drives"; click Ok
--THIS WILL DELETE ALL SYSTEM RESTORE POINTS ALREADY CREATED---
repeat and UNCHECK that setting.
this should get things "reset" and working again.
Note: SR will not make a restore point unless the system is allowed to
idle. If you are the type that turns on the pc, works, and then turns it
off for the day, then SR will not have a chance to make any restore
points. you need to let it idle for about 30 mins.
you can force the idle task processing to take place, with this command
line:
%windir%\system32\rundll32.exe advapi32.dll,ProcessIdleTasks
I like to put this into a shortcut for easy access.
Reply to frodo
I was hoping the event log would be of help.
Go to Start - Run and type Services.msc then press enter. Look under the Status column for
any entries that read "Starting" rather than "Started".
Click Start, click Run, and then type CMD then press enter.
Type Net Start at the command prompt and press enter. Make sure that the Task Scheduler
and System Restore Service is up and running. Also look to see if iis is running. If so
let me know.
How much disk space is System Restore using to hold restore points?
Regards,
> those are all notes for each of my successful manually
> self-evident, and do not need to be copied and pasted to
> this post.
> "Bert Kinney" wrote
>> Hi,
>> name column in the right pane to sort by source name,
>> button below the two arrows in the upper right corner.
>> Paste the information for each of the two event here.
>> Regards,
>>> "Bert Kinney" wrote
>>>> < inline >
>>>>> automatically creating System Checkpoints. It is
>>>>> not any of the other Disk Cleanup options. So, I
>>>>> the ones which I have Manually created since..
>>>>> RPGlobalInterval
>>>>> and it will restore from them, and undo the restores
>>>>> create System Checkpoints every 24 hours. I did
>>>>> not do a Windows
>>>>> installed was Kelly's TaskbarRepairToolPlus!. Does
>>>>> haters, saying that it is garbage. That is not constructive.
>>>> Regards,
Reply to Anonymous
There are 1173 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
