Need a phone with turn by turn navigation without data
Last response: in Cell Phones & Smartphones
June 25, 2012 5:52:36 AM
Is there such a thing as a phone with turn by turn capabilities that doesn't require a data plan, or that uses offline maps or pre-cached maps?
Right now I have a net10 r355c and it's $15 a month and I don' t need a smartphone other than for GPS turn by turn navigation
any phone/any carrier will work. cheaper the better.
June 25, 2012 3:35:07 PM
buy a gps unit from tom-tom, garmin or other manufacturer.
the gps navigation apps i've seen all use data to get the map tiles and to start the guidance.
June 25, 2012 9:23:38 PM
Unfortunately you cannot buy a smartphone w/o buying a data plan.
Actually you can... but you need to buy an unlocked phone, but that means paying full price for the phone which can generally be anywhere from $400 - $700 for the phone. Then you need to buy a 3rd party GPS program which includes the maps a part of the package an that usually costs between $50 - $99. You can then go to a carrier and maybe... maybe they will hook you up with just a voice plan.
In the end, it cheaper to just buy a dedicated GPS device.
