Tom's Hardware > Forum > CPU & Components > CPUs > duron 1300 doesn't work, power problem ? *DELETED*
Forum CPU & Components : CPUs - duron 1300 doesn't work, power problem ? *DELETED*
Sponsored Links
Your beep code explanation doesn't make sense. But if you are seeing the video card then it stops the culprit could be your ram. Maybe you can relisten to your beeps and then go into google and search for BIOS BEEP CODES. It will give you the info you need.
I'm not familiar with either processor (I went straight from P3 to Athlon) But did you have to increase your FSB to support the duron? if so then maybe its too much for the ram.
LAter
phr0Ze
I've been hiding in the shadows @ THG since 97.
AMD1800/768MB/9700Pro/Dragon+/240GigRaid0/DoubleWide with Redundant 350watt
Reply to phr0ze
There are 1169 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
