G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
looking for any good advice to repair my recently bought CIRQUS
VOLTAIRE as it has a mind of its
own and seems to be almost possesed,have had this game on my wish list
for a few years and this
one has spent a large part of its life with an out of order sign on it
at MAGIC MOUNTAIN, have included a few pics if anyones interested.
http://pinballswanted.com/images/circus1
http://pinballswanted.com/images/circus2
http://pinballswanted.com/images/circus3
http://pinballswanted.com/images/circus4
was warned about buying this particular game from some frustrated techs
but its such a fabulous looking pinball and in real nice cosmetic shape
from sitting in a dark area for so long
(also the only one i know of in my area ) that i thought id take my
chances.
firstly i can manually play a full game if i push ball into plunger
lane to start game off, and all fuses are good in the headboard and
optos appear good in ball trough even though solenoid wont work to kick
ball up to plunger lane.
main problem appears to be related to the RINGMASTER as when i first
turn game on and it goes into test mode the RINGMASTER doesnt move or
do anything and it comes up with a series of messages all connected to
RINGMASTER and basically says failed the tests(here is a pic)
http://pinballswanted.com/images/circus5
ive had a look underneath playfield and the 3 micro switches all feel
like there clicking correctly and register in the switch test.
i can manually turn RINGMASTER motor with machine switched off (with a
bit of effort) and lift head up and down ,so motor isnt seized,and if i
put it into auto test mode comes up with message "ERROR NO MOTION" ,i
have a manual and
it says to check red led and that comes on so power is getting to it.
does have other problems and the kicker solenoid in plunger lane seems
to go mental and work a lot more than it should,i done a solenoid test
and plunger lane ball kicker activated everytime
when solenoids 2 ,3 ,4 ,5 ,6 ,7 ,8 ,33 ,36 is tested in auto solenoid
test mode and if i hit right flipper button in game mode the flipper
sometimes works but more often than not the plunger lane kicker
solenoid works as well.
some other things dont work on playfield just basic stuff like left and
right sling,bumpers,(dissapearing bumper activates and works though)and
it wont kick ball out of ball trough into
plunger lane (as previously mentioned)etc and probably some other
faults i havent discovered yet.
any help/advice will be very much appreciated,thanks,
jeff www.pinballswanted.com
chances.
have a manual and
