G Guest Guest Feb 28, 2010 #1 I just bought the Bose wave Radio in US and I am getting my next assignment in india. Will this radio system work in all countries
jaguarskx Titan Apr 19, 2006 27,979 3 84,965 Mar 1, 2010 #2 Why don't you ask Bose if can? If not then buy an adapter that converts whatever voltage / frequency in India to what the US uses (115v, 60Hz). Upvote 0 Downvote
Y yachadm Distinguished Jul 7, 2011 1 0 18,510 Jul 7, 2011 #3 Right here is what you need to do to modify the circuits correctly: http://www.condoraudio.com/wp-conte...VoltageConversion-Restoration-Repair.pdf[url] Upvote 0 Downvote
ssddx Titan May 27, 2009 17,054 5 74,965 Jul 25, 2011 #4 i wouldnt modify the actual radio, just modify the input going into it to the right voltage, amperage, frequency. modifying the radio is just a bad idea. Upvote 0 Downvote
