A HP workstation and a problem with dual displays
  • Hewlett Packard
  • Workstations
  • Computers
  • Displays
Last response: in Computer Brands
June 20, 2011 6:48:45 AM
Hello, I'm a new member here and what's a better way to start a monday than with a problem?
I've got a HP Compaq 8000 Elite workstation with a NVidia GeForce 310 gpu with a DVI and Display port. I have a display attached to the DVI-port, but I'd like to attach another display to the motherboard's vga port (the other display being slightly older with no other ways to connect it).
The problem is that I can't get any picture to the display connected to the motherboard. Is this because the NVidia gpu? Is there any way to get a picture to the second display without having to buy any adapters or so on?
More about : workstation problem dual displays
June 20, 2011 9:44:21 PM
Have you checked you Nvidia control panel for dual display options?
June 21, 2011 5:29:59 AM
Yes I have, but the NVidia controlpanel doesn't recognize my second display. Is this problem caused by the fact that I have a separate gpu and it overrides the one on the motherboard?
June 24, 2011 4:09:06 AM
Yes.
When you install a discrete graphics card into a computer, the mainboard recognizes this and turns off the on-board video. Not many mainboards will let you run the on-board with a video card.
June 26, 2011 9:57:20 PM
You probably need to buy something like http://store.nvidia.com/store/nvidia/en_US/pd/productID... to allow you to connect the VGA monitor to the Displayport connection on your graphics card.
June 27, 2011 3:13:49 PM
I can verify ShadeTreeTech. The onboard on these is disabled. However, I recommend NOT using a displayport to VGA adapter. They SUCK badly. We have stopped buying them due to stability issues.
On your setup, what you need to do is connect a DVI to VGA adapter to the VGA monitor and Displayport to DVI to your other monitor.
May 27, 2013 9:13:17 AM
Yes, this is an old thread, but I do know the answer.
On your computer, there are likely 2 DisplayPorts. One on the main chassis, and one on the DVI add-on card. If you have the add-on card, the motherboard DisplayPort is disabled. The one on the card is live, however. Plug into it (you'll have both displays plugged into the card with different interfaces) and it will work. Every time.
