Archived from groups: rec.games.pinball (
More info?)
The BaronVonBell wrote:
> Hi,
> Just started shopping out my recently acquired RRGVCOASAATDDOW (nod to
> Rick S.)
> And, was wondering is there a "best" way to remove the old spinner
> decals to prep for the new set?
> Tim
I just did my decal replacement last week.
I found that the old decals were easy to slowly peel off with just
using a small screwdriver or X-Acto knife to start the lift on the O.D.
and then grab with needle nose pliers, then with your fingers. Slowly
peel away then clean the plastic spinners with alcohol. I did this
while everything was still on the machine.
I also tried one with cutting in the center where the screw is and then
start peeling/tearing. That works too.
The adhesive on my old spinner decals was not very aggressive but it is
sticky.
If for some reason your adhesive is really aggressive then I would
remove the discs first as suggested in a previous post.
It ended up much easier than I expected.
Aslo, make sure you adjust the spinning disc heights (from under the
playfield) after applying the new decals. That affects the
functionality of the discs during game play.
